2/9/19 .8 Hour Attached the fuel flow and fuel pressure assemble to fuel pump. Moved it to a couple of different angles. I don't like the architecture. Will have to think of something else. Maybe mount the flow sensor inside the cabin and the pressure sensor directly to the fuel pump. Tried to do some wire labeling but too cold. Seven outside, 42F in shelter. Called it a day.
2/10/19 1.9 Hours Finished labeling that I tried to do yesterday. Attached shunt to firewall with #10 washerhead screws and nuts. Enlarged hole for firewall sensor wires padded clamp to #10.
2/11/19 1.8 Hours Got the pitot/static lines identified at the left wing root and marked. Enlarged holes on each wing root for wires from wing into fuselage.Ran strobe light syns wire from one side to other. Moved twisted trio for fuel flow sensor to cabin side of firewall. Identified location for Dynon back-up battery on right inside of center consol and drilled # 8 holes for mounting.
