Jay's Cruzer
Date:  1-19-2019
Number of Hours:  7.00
Brief Description:  Fuel lines, solinoid
1/17/19
1.5 Hours
Made template from cardboard for aft wing root for placement of fuel lines, pitot/static and wireing. Drilled two holes, one each side in cabin side channel, for padded clamps to hold fuel lines. Clecoed lines into place, Cut fuel line to approx length.
1/18/19
Received parts from SteinAir and ASS.
1.7 Hours
Appliied Noalox to back of solinoid then with Norma holding the bolt from the inside, bolted the master solinoid into place. Deburred bolt holes in the firewall for the radio. Added labels, terminals and heat shrink to power wires of the Dynon HDX1100. Mark location for Dynon back-up battery on center console side pannel, 3 inches down form top to clear parking brake cable.
1/19/19
3.8 Hours
Made template from scrap metal for aft wing root for placement of fuel line, pitot/static and wiring. Drilled holes and mounted fittings into template. Had Paul take a look. Used template to mark locations on fuselage sides. Drilled hole on left side fuselage for fuel line 90 deg elbow. Will move hole slightly foreward for right side. Cut off top of cabin side channel cover to make access room on inside of skin.
Master solinoid
Master solinoid
Template
Template
Factory (L), mine (R)
