1/8/19 1.2 Hours Replaced the three A5 rivets without bracket removed yesterday. Pluged cables int hub box, Attached ring terminal to power and ground (red & black) wires.
1/9/19 2.5 Hours Clecoed power panel into panel. Changed vertical faceplate on intercomm unit to horizontal. Found it strange that the hold down nuts of faceplate were 10 mm. Modified mic/phone jack holder to fit on top of foreward center console and marked location for wire access hole.
1/10/19 2.0 Hours Drilled accesss hole in center console for phone and mic jacks. Filled opening for comm control head to fit. Drilled two holes in mic/phone holder for attaching holder to consol. Marked location for radio and transponder. Trail placed comm antenna. Will have to go on top.
