Jay's Cruzer
Date:  12-1-2018
Number of Hours:  8.90
Brief Description:  Instrument Panel & brake lines
11/29/18
4.7 Hours
Removed instrument panels from aircraft. Spent the entire time dressing the rectangles in the panel using a Dremel cut-off wheel. Marked the location for trim indicator. Put panels back into aircraft.
11/30/18
2.1 Hours
Cut the ELT monitor and the trim indicator holes. Dressed holes and got trim indicator to fit. Continuued to dress other holes and got the power panel to fit.
12/1/18
2.1 Hours
Put two pieces 1/4" steel rod into two 3/8" padded clamps and squashed clamps in vise to hold the two 1/4" brake lines. Installed the two clamps with brake lines in center console, one at aft end and one about mid way. Continued to dress instrumental panels.
Instrument panel cut-out
2 mag switches and 2 cuircut breakers to go
Brake lines secured
Brake lines secured
