Jay's Cruzer
Date:  11-18-2018
Number of Hours:  5.60
Brief Description:  Throttle
11/16/18
3.5 Hours
Drilled small (7/64") mounting holes for USB data plug in center console. Rotated the water pump input to right side. Spent most of time working on throttle cable for the left carb.
11/17/18 Snow day.
11/18/18
2.1 Hours
Finished the right throttle and partial completed right choke. The cable sheath is a tad bigger than the cable adjusters. Scraped and sanded the sheath then lubed to get it into the adjuster. Measure sheath carefully. There is not too much maybe not enough. Right choke fair lead on carb needs to be bent down. Have to see how to do that without kinking the tube.
Left throttle coble
Left throttle coble
Right throttle and choke
