11/11/18 2.4 Hours Attached the two oil lines to the oil cooler. Temp attached oil line to oil pump. Put anti-viberation bumpers on bottom of radiator and place on mount. Up drilled radiator-engine braces and temp attached. Removed muffler from aircraft to work on upper left port.
11/12/18 2.4 Hours Cut off 1/4 inch from top of anti-viberation screws to allow easy install. Delabeled and deburred radiator mounts. Installed short piece of hose to radiator elbow. Used large socket (1 3/8" OD) and hammer to round out muffler port. Lots better.
