Brief Description: Throttles and rivet right rear fuselage
10/18/18 4.0 Hours Cut throttle and choke cables to length. Installed right side throttle rod after cutting slot in firewall.
10/19/18 3.5 Hours A5 riveted right rear fuselage that were missing from the QBK. Determined that the pilot side throttle knob need to be moved an inch and a half to right of predrilled hole. Too close to door jam as is (only about a half inch between knob and jamb edge).
