KC - Harmon Rocket II
Date:  1-16-2012
Brief Description:  Made HS rear spar jig mounts
My first job today was to make and install brackets onto the jig for mounting the HS rear spar along the hinge line. Using my new cross-slide vice made it relatively easy to achieve a constant height above the mounting surface (and therefore a straight hinge-line).
cross-slide vise in action
a jig hinge bracket
a jig hinge bracket
HS spar on jig
HS spar on jig
