Kenneths Web Site
Date:  2-3-2011
Number of Hours:  3.00
Manual Reference:  Disk 26
Brief Description:  Working on the pitot tube.
Had a neighber mill out of a block of aluminum a pitot tube, I then drilled a 90 degree hole for the air speed and a 62 degree hole for the aoa, will have to wait and see how well it works.
Here is the rough milled pitot tube.
Here I have cut it off the base.
This is a rough set up I have a lot of sanding to do.
