Shimming out the windshield befor I apply the fiberglass shroud around the windshield. I plan on putting a removable shroud around the windshield instead of the perminent one that vans urges you to put on, I feel if the windshield gets damaged down the road it will be easyto change.
Here is the shim on the left side to bring the windshield out where it belongs.
Here is the shim on the right side that brings the windshield out where it belongs
Here are a couple of the clips that hold the front of the windshield down.
