Kenneths Web Site
RV9A
Cowling
4-15-2007
Mating the top- and lower colwing to each other.
I located and clecoed a piece of alum strip to the bottom cowling, I then fit the top cowling and drilled and clecoed where the #6 screws will go.
You can see clecoes holding the strip between the two halves.
Here you can see the lower half with the strip clecoed on,along with the RV dog.
Here you can see where the screws will be located to hold the top cowling on.
RV9A Home
1537
Aileron left
Aileron right
Ailerons both
Baffeling
Cowling
Electrial
Engine 0-320
Exhaust
Flaps left
Flaps right
Fuel Line
Fuel tank left
Fuel tank right
Fuel Tanks
504
Inspection
Instrument panel
Instrument panel
Jigs
Leading edge light.
Lighting.
Oil Cooler
Pitot tube
Rear spar both
Rear spar left
Rear spar right
Shop Cleaning
Spinner
Vertical stabelizer
Wign spar left
Windshield
Wing left
Wing ribs
Wing right
Wing spar right
Wingtip both
Wingtip left
Wingtip right
Wireing
Wiring
