Kenneths Web Site
RV9A
Baffeling
8-10-2008
Disk 19
Running scat tube to heat muff.
Cut a 2" hole in the back of the baffeling to run my scat tube from to the heat muff.
Cutting the hole in the back of the baffeling..
Rivited on a piece of 2" tubing.
Ran the scat tub from the baffelinjg to the heat muff.
RV9A Home
1537
Aileron left
Aileron right
Ailerons both
Baffeling
Cowling
Electrial
Engine 0-320
Exhaust
Flaps left
Flaps right
Fuel Line
Fuel tank left
Fuel tank right
Fuel Tanks
504
Inspection
Instrument panel
Instrument panel
Jigs
Leading edge light.
Lighting.
Oil Cooler
Pitot tube
Rear spar both
Rear spar left
Rear spar right
Shop Cleaning
Spinner
Vertical stabelizer
Wign spar left
Windshield
Wing left
Wing ribs
Wing right
Wing spar right
Wingtip both
Wingtip left
Wingtip right
Wireing
Wiring
