Brief Description: Drilling,mounting, and locating the map light hole
I took the center supports and located the hols in the supports for the map lights to be mounted in. I then located the center support ovet the center uprights and drilled the support on. After deburing I rivited the support on.
Locating where the map light will go in the center support.
Here is the final hole with the light lying next to it.
