Installed two new breakers a five amp for the efis and ap74 and a three amp for the two servo motors. I finished wiring the pitch servo, Finished putting the #6 tapped holes in the roll bar for the windshield and fairing.Drilled a 1/2 inch hole and added a rubber gromet in the top of my windscreen for the gps intenna wire to run through. Ordered the black mat material that will sit ontop of the windscreen and the rubber that will be mounted to the front of the windscreen.
