Kenneths Web Site
RV9A
Disk 23
Made brackets for brake lines and external power g
Made brackets for the duel brake lines and for the external power ground cable.
Here are the two brackets one for external powere ground the other for brake lines.
Here is the external power ground mounted to the bracket.
Here are the brake lines mounted to thye bracket
RV9A Home
1537
Aileron left
Aileron right
Ailerons both
Baffeling
Cowling
Electrial
Engine 0-320
Exhaust
Flaps left
Flaps right
Fuel Line
Fuel tank left
Fuel tank right
Fuel Tanks
504
Inspection
Instrument panel
Instrument panel
Jigs
Leading edge light.
Lighting.
Oil Cooler
Pitot tube
Rear spar both
Rear spar left
Rear spar right
Shop Cleaning
Spinner
Vertical stabelizer
Wign spar left
Windshield
Wing left
Wing ribs
Wing right
Wing spar right
Wingtip both
Wingtip left
Wingtip right
Wireing
Wiring
