Kenneths Web Site
RV9A
Disk 10
Building the battery hold down bar.
Cut and drilled all the holes in the hold down bar, made the 7/8 spacers for the bolt to go through, and then fit it to the battery box.
Drilled all the holes in the hold down bar.
Made the shims that the hoddown bolts go through.
Here is everythin bolted together.
RV9A Home
1537
Aileron left
Aileron right
Ailerons both
Baffeling
Cowling
Electrial
Engine 0-320
Exhaust
Flaps left
Flaps right
Fuel Line
Fuel tank left
Fuel tank right
Fuel Tanks
504
Inspection
Instrument panel
Instrument panel
Jigs
Leading edge light.
Lighting.
Oil Cooler
Pitot tube
Rear spar both
Rear spar left
Rear spar right
Shop Cleaning
Spinner
Vertical stabelizer
Wign spar left
Windshield
Wing left
Wing ribs
Wing right
Wing spar right
Wingtip both
Wingtip left
Wingtip right
Wireing
Wiring
