Kenneths Web Site
RV9A
Built the seats.
I cut the hingees and clecoed and drilled them to the seat pans, I then cut all parts to make the seats,drilled and clecoed everything together
Here are the hinges clecoed to the seat pans.
Here are the seats clecoed together and sitting in the fuselage.
Here is the framework on the back of the seat mounted in their support.
RV9A Home
1537
Aileron left
Aileron right
Ailerons both
Baffeling
Cowling
Electrial
Engine 0-320
Exhaust
Flaps left
Flaps right
Fuel Line
Fuel tank left
Fuel tank right
Fuel Tanks
504
Inspection
Instrument panel
Instrument panel
Jigs
Leading edge light.
Lighting.
Oil Cooler
Pitot tube
Rear spar both
Rear spar left
Rear spar right
Shop Cleaning
Spinner
Vertical stabelizer
Wign spar left
Windshield
Wing left
Wing ribs
Wing right
Wing spar right
Wingtip both
Wingtip left
Wingtip right
Wireing
Wiring
