Kenneths Web Site
RV9A
Squared the fuselage and drilled the rear deck pla
We turned the fuselage over and it was then levaled before I drilled the rear deck plate to the longerons.
Here you can see the longeron on the side of the fuselage at the center secrtion is leval
This showes the center section being leval from side to side.
This showes the rear deck plate being leval before I driiled and clecoed it to the longerons.
RV9A Home
1537
Aileron left
Aileron right
Ailerons both
Baffeling
Cowling
Electrial
Engine 0-320
Exhaust
Flaps left
Flaps right
Fuel Line
Fuel tank left
Fuel tank right
Fuel Tanks
504
Inspection
Instrument panel
Instrument panel
Jigs
Leading edge light.
Lighting.
Oil Cooler
Pitot tube
Rear spar both
Rear spar left
Rear spar right
Shop Cleaning
Spinner
Vertical stabelizer
Wign spar left
Windshield
Wing left
Wing ribs
Wing right
Wing spar right
Wingtip both
Wingtip left
Wingtip right
Wireing
Wiring
