Brief Description: Putting rivits in holes and building the saw bucks
I started makeing the bucks that will sit under the fuselage after it is flipped over, I also went through and put rivits in the holes that are left that need to be rivited.
Here is the saw buck I cut down to 20 inches high, it will sit under the center fuselage .
I will cut this buck down to approximately 31 inches and it will go under the rear of the fuselage.
