Kenneths Web Site
RV9A
Drillling side pannels.
Drilled the side panels to the utside seat rib, drilled the side pannel to the firewall, and drilled the bottom skin to the rear fuselage.
Here the side skin drilled to the seat roi.
Here the the bottom skin is drilled to the rear fuselage.
Here the side skin is drilled to the firewall.
RV9A Home
1537
Aileron left
Aileron right
Ailerons both
Baffeling
Cowling
Electrial
Engine 0-320
Exhaust
Flaps left
Flaps right
Fuel Line
Fuel tank left
Fuel tank right
Fuel Tanks
504
Inspection
Instrument panel
Instrument panel
Jigs
Leading edge light.
Lighting.
Oil Cooler
Pitot tube
Rear spar both
Rear spar left
Rear spar right
Shop Cleaning
Spinner
Vertical stabelizer
Wign spar left
Windshield
Wing left
Wing ribs
Wing right
Wing spar right
Wingtip both
Wingtip left
Wingtip right
Wireing
Wiring
