Attached the finished center section to the back fuselage. I then mounted the side skins tieing in the rear and center fuselage sections, I then drilled the holes for the step s that will be mounted in the side of the fuselage.
Here are the side skins mounted .
Here you can see the inside of the center section.
This shows the hole for the step that will be mounted.
