Brief Description: Making shims and working on ribs.
Making shims and working on the seat ribs. I had to open up four of the ribs so the contro stick would work without obstruction, I then had to remove the top section of two of the ribs so the control stick can be removed without a problem.
Here are the shims that will locate behind the seat ribs.
I had to open up four of the seat ribs for the control stick.
Here are two seat ribs with sections removed to fit the control
