Brief Description: Preparing control arm brackets.
Cleaned up the control arm brackets. I then primed located and drilled them onto the center section, I then mounted the control arms to make sure everything fit.
Control arm brackets.
Here I locatedthe brackets to the center section.
Here the control arms are mounted to the brackets.
