Kenneths Web Site
RV9A
Fuel tank left
4-14-2002
Sealing the end rib of the fuel tank.
Pro sealed and rivited the ring stifner to the end rib. pro sealed the fuel pick up to the inspection plate also rivited the antirotation bracket on.
Riviting the platenuts and ring stifner to inspection plate.
Showing the ring stifner on the end rib.
Fuel pickup and antirotation bracket on the inspection plate.
RV9A Home
1537
Aileron left
Aileron right
Ailerons both
Baffeling
Cowling
Electrial
Engine 0-320
Exhaust
Flaps left
Flaps right
Fuel Line
Fuel tank left
Fuel tank right
Fuel Tanks
504
Inspection
Instrument panel
Instrument panel
Jigs
Leading edge light.
Lighting.
Oil Cooler
Pitot tube
Rear spar both
Rear spar left
Rear spar right
Shop Cleaning
Spinner
Vertical stabelizer
Wign spar left
Windshield
Wing left
Wing ribs
Wing right
Wing spar right
Wingtip both
Wingtip left
Wingtip right
Wireing
Wiring
