Kenneths Web Site
RV9A
Fuel tank right
4-14-2002
Sealing the end rib of the fuel tank.
Rivited the stifner ring with pro seal to the end rib, also pro sealed the fuel pickup and rivited the antirotation bracket on.
Pro sealed and rivited the stifner ring to the end rib.
Pro seald and rivited the antirotation bracketon inspection plt.
This is the outside view of the inspection plate.
RV9A Home
1537
Aileron left
Aileron right
Ailerons both
Baffeling
Cowling
Electrial
Engine 0-320
Exhaust
Flaps left
Flaps right
Fuel Line
Fuel tank left
Fuel tank right
Fuel Tanks
504
Inspection
Instrument panel
Instrument panel
Jigs
Leading edge light.
Lighting.
Oil Cooler
Pitot tube
Rear spar both
Rear spar left
Rear spar right
Shop Cleaning
Spinner
Vertical stabelizer
Wign spar left
Windshield
Wing left
Wing ribs
Wing right
Wing spar right
Wingtip both
Wingtip left
Wingtip right
Wireing
Wiring
