Kenneths Web Site
RV9A
Fuel tank right
3-13-2002
Working on the cover for the fuel tank.
Finished deburing and dimpling the cover plate that seals off ther last rib in the fuel tank.
Drilled the hole for the fuel line to go through the cover plate.
Fitting the fuel line conection .
The other view of ther fuel line conection.
RV9A Home
1537
Aileron left
Aileron right
Ailerons both
Baffeling
Cowling
Electrial
Engine 0-320
Exhaust
Flaps left
Flaps right
Fuel Line
Fuel tank left
Fuel tank right
Fuel Tanks
504
Inspection
Instrument panel
Instrument panel
Jigs
Leading edge light.
Lighting.
Oil Cooler
Pitot tube
Rear spar both
Rear spar left
Rear spar right
Shop Cleaning
Spinner
Vertical stabelizer
Wign spar left
Windshield
Wing left
Wing ribs
Wing right
Wing spar right
Wingtip both
Wingtip left
Wingtip right
Wireing
Wiring
