Kenneths Web Site
RV9A
Disk 20
Removing instrument panel to cutin the instruments
Removed the instrument panel so I could start cutting in the instruments and switches.
Here is thye mess after I removed the instrument panel.
Here is the instrument panel befor I started cutting.
Here I have started cutting in the instruments and the switches.
RV9A Home
1537
Aileron left
Aileron right
Ailerons both
Baffeling
Cowling
Electrial
Engine 0-320
Exhaust
Flaps left
Flaps right
Fuel Line
Fuel tank left
Fuel tank right
Fuel Tanks
504
Inspection
Instrument panel
Instrument panel
Jigs
Leading edge light.
Lighting.
Oil Cooler
Pitot tube
Rear spar both
Rear spar left
Rear spar right
Shop Cleaning
Spinner
Vertical stabelizer
Wign spar left
Windshield
Wing left
Wing ribs
Wing right
Wing spar right
Wingtip both
Wingtip left
Wingtip right
Wireing
Wiring
