Kenneths Web Site
RV9A
Disk 27
Drilled holes in spinner mounting it to the prop a
Drilled the spinner to the prop and bulk heads after makeing sure the spinner was square with the prop. I then made the filler plates for the spinner.
Makeing sure the spinner was seated and not out of round.
Makeing one of the filler plates for yhr spinner.
Locating the filler plate on the spinner.
RV9A Home
1537
Aileron left
Aileron right
Ailerons both
Baffeling
Cowling
Electrial
Engine 0-320
Exhaust
Flaps left
Flaps right
Fuel Line
Fuel tank left
Fuel tank right
Fuel Tanks
504
Inspection
Instrument panel
Instrument panel
Jigs
Leading edge light.
Lighting.
Oil Cooler
Pitot tube
Rear spar both
Rear spar left
Rear spar right
Shop Cleaning
Spinner
Vertical stabelizer
Wign spar left
Windshield
Wing left
Wing ribs
Wing right
Wing spar right
Wingtip both
Wingtip left
Wingtip right
Wireing
Wiring
