Kenneths Web Site
Date:  3-3-2006
Number of Hours:  3.00
Manual Reference:  Disk 11
Brief Description:  Mounted the left flap bracket.
Drilled a hole into the bottom of the fueslage on the laft side so the flap bracket could go through the fuselage and then bolt onto the flap.
Here is a hole drilled through the bottom of the fuselage.
here is a photo of the flap in the down position
Here you can see the flap bracket coming through the fuselage bolting onto the flap.
