Kenneths Web Site
Date:  2-4-2006
Number of Hours:  8.00
Manual Reference:  Disk 9
Brief Description:  Drilling and fitting the sub panal and rollbar.
I located and drilled the holes for the rollbar on the top of the fuselage, I then mounted the rollbar brace to the sub panel and determened what length it needed to be to fit the rollbar, I then located and drilled the brace to the sub panel and rollbar.
I am drilling the holes for the  rollbar to bolt to the fuselage.
Here is the rollbar brace bolted to the rollbar.
Here is the rollbar brace bolted to the sub panel.
