Kenneths Web Site
RV9A
Instaling the vertical stabelizer.
I drilled and bolted the vertical stabelizer to the rear of the fuselage.
Here is the bottom of the vertical stabelizer bolted to the back of the fuselage.
Here is the middle of the vertical stabelizer bolted to the rear fuselage.
Here is the front of the vertical stbelizer bolted to the horizontal stabelizer.
RV9A Home
1537
Aileron left
Aileron right
Ailerons both
Baffeling
Cowling
Electrial
Engine 0-320
Exhaust
Flaps left
Flaps right
Fuel Line
Fuel tank left
Fuel tank right
Fuel Tanks
504
Inspection
Instrument panel
Instrument panel
Jigs
Leading edge light.
Lighting.
Oil Cooler
Pitot tube
Rear spar both
Rear spar left
Rear spar right
Shop Cleaning
Spinner
Vertical stabelizer
Wign spar left
Windshield
Wing left
Wing ribs
Wing right
Wing spar right
Wingtip both
Wingtip left
Wingtip right
Wireing
Wiring
