Bill & Brendas RV-8 QB
Date:  8-11-2014
Number of Hours:  0.50
Brief Description:  Sand and round trailing edge of rt wing tip
I had previously traced a line across the rt wing tip trailing edge in line with the aileron TE. So today I simply used a block sandcer to sand to that edge and then started rounded it out to match the aileron radius. I still need to work both sides for even radius and then add some filler inside the edge to reinforce.
Sanded the right side wing tip TE even with the aileron and rounded some. needs more work still
