Bill & Brendas RV-8 QB
Date:  11-3-2014
Number of Hours:  1.00
Brief Description:  Final fab attach bolts and heat door cable secure
previous scat tube routing had the scat tube laying on the top of fab and against the rt exhaust tube. I fixed this by cutting some aluminum spacers to lift the adel clamp om rt side and again for the stainless steel scat tube clamp to lift it away from the fab as well as to secure it from the the travel limits of the throtle lever on carb.
re routed the scatr tube to the cabin heat inlet to get some more do=istance from the exhaust pipes
the fwd adel cushion clamp to the carvb heat door was secured with somne safety wire to protect from hardening and or cracking of the runbber cusihion of the adel clamp and keepting the cable sheath from moving in time of need. this was suggeted from the EAA builders webb site.
