Brief Description: sand windscreen inside corners and under aft lip
no pics to bore with on this but I sanded the micro applied to inside corners. Not happy with result yet so I will need to apply more micro again.
The aft part of the fairing over the bow had a ugly finish on the bottom side that seals up over tha canopy when closed. Though its only visible when canopy open, I wanted it smoother. So I applied micro to it yesterday and though it would be a quick sanding session to smooth out. Wrong! As I have found out, this epoxy never sands easily or quickly and what seems like a small amt to sand always ends up taking me much too long to sand down. This underside sanding was a pain and took me at least an hour and half. But it looks better and should look even better after I spray primer on it.
