Sanded down the previous layup for good defined tape line and for good adhesion of next layer of epoxy. Blew off dust with compressed air as always and cleaned. Mixed up couple batches of micro using my west systems grey pigment now. I first applied it to the areas that seemed to be the low spots and all along the lower front windscren fairing. I let it dry for 3.5 to 4 hours and then sanded smooth on the left side. I used the fast hardner but it still could use some more cure time because it seems to be clogging up the paper. So ill wait until next sesion to finish the other side,
The plan will be to sand and apply another thinner layer of micro and then a layer of plain epoxy. Then I hope to spray on some build primer eventually removin the tape border and then moving on to other things We will see I guess
icro with grey pigment after another sanding session
