Brief Description: skirts-12 (aprox) and trim canopy front edge again
Today was not realy worth logging but.. 1. Trimmed the right skirt along the top edge after I applied some pin stripe to make a nice cut line. 2. Cut and smoothed in the radius on the top edge in the aft radius. 3. Sanded the top edge of the right skirt some 4. Applied a single layer of BID glass and epoxy to front end of rleft skirt to provide more edge distance for the rivit there. 5. Put a small square of BID and epoxy over several elongated rivit holes on the right skirt
The canopy was moved forward when final clamped and drilled earlier this summer. Today I applied some pin stripe and re cut the front edge and sanded. I also had the same cardboard in place as before and could see where the center was before as a back up. Dont know how or if this will affect the fit of wind screen or not but that will be dealt with when the time comes.
