Today I made more card templates and then transfered to rubber. The fwd pieces dont need to be quite as tall as the rest and seems to fit better if not. The time consuming part of this is the multiple times the top cowl is put on and then removed for each piece.. I think the right side is good to go and can be rivited on. The left side is a bit tight and needs spme adjusting I think.
