Fitted by sanding down edges as required to fit side baffles to cylinders and then fitted the aft bafffles as instructed along with the center support. This required many on and off itterations with trimming as required before they fit right.
The left and right forward inlet ramps were previously deburred and edged and so today I clecoed the pieces together as shown in dwg OP40-8 and final drilled and reamered and countersunk where required. Dissassembled and deburred. Reassemble with clecos and fit to front cylinders
Baffles fitted to sides and aft of 3 and 4 cylinders
Aft center bracket installed and used to match drill aft baffles
