Brief Description: oil door rivited on to cowl and wet sanded primer
I first wet sanded the primer that was applied to the top cowl and then also to the bottom cwl around the intake snout.
Counter sunk the 6 rivit holes for the oil door and then squeezed the an426 3-5 rivits 6 times to secure the door hinge to the cowl. Used half size longer rivits than what was called out in plans since i added a shim under the door hinge., worked well.
