Brief Description: Lower cowl cooling inlet seals fabricated abd inst
Cut and hand rolled the radius into the ends of some 062 X 1/2" aluminum strips. These need to be bent on the small side so that they will hold the fabric seal tight against the cowl on each end.
I put a center line on the strips with black sharpie for alignment later
Marked three screw holes on the inlet about 3/.8" from back edge and then drilled #30
Clamped the alum back strip in place so that my center lone was centered in the drilled holes and then match drilled it
Cut a 12" X 2.5" strip of baffle seal and applied 1" wide tape along the edge I want attached to cowl. Clamped in place and match drilled it as well.
Updrilled everyting for #6 screws and then countersunk the screw holes in the cowl and then fastened in place.
