Light finish sanding and then clean with a tack cloth and acetone of the top cowl I then started to spray on some primer when I noticed it was not even close to ready for primer. Sanded off the primer and applied a coat of epoxy mix with acetone Let dray a few hours to somewhat dry to touch(using fast dry hardnet now) Applied a second coat today before first coat cured I added some gray tint to see if it will help during sanding to keep me from sanding off too much
Added some glass to the upper corners of baggage door recess. This area is not covered with the door or hinge and looks bad not filled in, I will sand this and then add filler to smooth out and then file until door fits again
Coat 3 and for of epoxy thinned with acetone applied to upper engine cowl
