Brief Description: Sanding top cowl and sand and fill work on bottom
I had brenda start sanding the micro on the top cowl while I wet sanded the primer on the bottom cowl. I then dry sanded some areas of the lower cowl in attempt to remove some scratches from the 80 grit paper earlier. I applied some filler to several areas where I could se some pin holes and divits. These areas can be sanded tomorrow and then another coat or two of primer.
Sanding almost done on top cowl?
Bottom cowl was wet sanded and some filler applied on problem areas
