Brief Description: Bottomr cowl bottom aft cuts for fit
The hours for this are mostly time of installing and then removing the bottom cowl several times. Its quite a deal doing by ones self.
Basicl I just would get the bottom cowl positioned and strappoed tight and the front screwed into the wood disc so it wouldnt move each time so I could mark the cut line from the 2 inch refrence line. Then Id cut and sand and then repeat the operation until it fit on the bottom
Tomorrow I will remove again and file a little more off the radius on right side and then reinstall so I can drill the botoom hinges to the cowl. Then I will be able to cut the sides at firewall and then the horizontal cuts.
