Brief Description: Lower cowl bottom hinges left and right sides
Cut two 6 inch lengths of 1/8" piano hinge and clamped to the left and bottom sides of lower firewall. Match drilled each hinge to the firewall flange.
removed hinges and deburred the holes and then counter sunkto fit over the dimples in firewall flange
Cut two lengths of stainless steel .125 hinge pin to aprox 8 inches. The extra length is what I hope is enough for required bends to scure pin in a bracket yet to be fabricated.
Also cut and match drilled a shim strip that will fit the rt side hinge if needed. I did this just to see if it will be required or not after fitting the lower cowl.
