Bill & Brendas RV-8 QB
Date:  6-4-2013
Number of Hours:  1.00
Brief Description:  eyball light final install and pilot stick grip re
Cut the ground wire from the switch terminal and removed the wire.
covered the terminal on switch with shrink tube since I wont need it.
drilled hole for #6 screw on front side of center bulk head for a ground wire pigtail and added dsub pins to connect the neg wire from light to ground and have revability later.
cut the power wire and inserted dsub pins on them as well
cut the pos wire from light to switch and iserted dsub pins there too. Now this switch and light plate is removable and has enough slack to pull off and get inside w/o undoing the dsubs.
All dsub pins covered in shrink tube. Bundled the wires together with spiral wrap and installed.
ops check good this time!
Wires cut, ground removed from switch D sub pins crimped on
local ground with #6 screw and short lengthe of pigtail
Final wire look after pins and shrink tube and spiral wrap
