Brief Description: Final stick grip, relays, trim wiring
Control grip final wiring front and back grips
Pitch and roll trim servo wiring completed
Intercom transmit from sticks wiring completed
sorted, bundle and tie wiring as neatly I could with zip ties and spiral wraprim
Installed the power wire 22awg from power trim post back to the relay. Note: I want to add an inline 1 amp fuse.
Powered up the trim servos at the power bar and ground lead to airframe with lawnmower battery to test the hat switch on pilot grip. Trim worked as I hoped. The other buttons are hooked up but need the wires added from radio and auto pilot later.
grounded the rear seat aux power on a floor rib. It wont be easily accessable there so I hop I dont have problems with it later after floor installed.
Adel cushion clamp installed to hold the pilot stick wire bundle clear
double relay module from tosten wired up and wires bundled and tied
term block for stick buttons wired and bundle tied
