Brief Description: Researching audio warning wire from EMS
Wasnt getting any warning tone in headset after using the test procedure listed in Dynon installer manual. I traced the wire from the rear of the EMS harness to the radio shack 10K ohm variable resistor. Checked the three wire connections at that point and then at the terminal block for the intercom audio. I couldnt find anything wrong. Will test the intercom aux audio and radio audio again tomorrow and confirm working before anything else with this detail.
