Pulled t resishe left and right RPM wires from the wire bundle forward of firewall back to behind the panel and rerouted to the right side to behind the ACS ignition switch.
Cut off some excess wires to use to pig tail off the ignition where the magnito P-leads attach. Connectorized
Located a small terminal block and the Dynon supplied 30Kohm resistors. Covered the resistors in shrink tube and attached to the terminal block. Connected a pig tail to the end of each resistor and then connected the other end of pig tail to the ignition switch at left and rifgt P-lead terminal. I then hooked the wires for the Dynon rpm to other ends.
Tucked the the terminal block in behind the ignition switch and zip tied to the harness from the switch.
This set up will hopefully allow me to added increasing resistance to the Dynon to stabilize the rpm fluctuations. I just need to unscrew the resistors and add ones with bigger resistance as required.
RPM pig tails to P-leads
RPM term block with resistors
Term block zip tied to ignition harness. View is lfrom above
