Brief Description: Install variable potentiometer for EMS audio warni
The Dynon install manual suggests a 10K ohm varriable resistor to adjust the audio warnings volume from the Dynon EMS. We bought one at radio shack and then decided on a location. The audio warning volume is set thru the EMS set up screen and then the adjustments made with this potentiometer. Once set, it stays at that volume. Therefore, I decided to install in an out of the way location that I could still reach from the seat. The cross brace behind the panel seems like a good spot and is reachable too. I will look for a knob to install on the bare shaft but its not visible or neccessary. Wired up per instruction
Potentiometer from radio shack for ems audio
Top side of the potentiometer mounted in cross brace
