Brief Description: GT50 final wire and second dimmer post installed a
I added a 1amp fuse to the hot battery buss for the GT50 memory and also added two more leqads to same connector for the dynon memory and another if needed. Coneected it up and tied up the extra leads. Labeled
labeled the extra post I had for power terminals on the 7 posts I had and will use this for my second dimmer module to dim cabin lights seperate from panel lights
GT50 and dynon clock and memory power to hot buss
Unused power buss post utilized for 2nd dimmer module
